I have a grid with 2 template columns next to each other if a specific value is selected in the first cell I need the second cell to enable/disable appropriately here is the xaml for my two cells
1rst cell that should initiate the enable eisable the value I'm looking at is the key
<igGrid:TemplateColumn Key="CategoryClass" IsFilterable="True" MinimumWidth="150" Width="Auto" IsResizable="True" IsReadOnly="True" FilterColumnSettings="{StaticResource FilterColumnSettingsBool}"> <igGrid:TemplateColumn.HeaderTemplate> <DataTemplate> <TextBlock Text="Type" /> </DataTemplate> </igGrid:TemplateColumn.HeaderTemplate> <igGrid:TemplateColumn.ItemTemplate> <DataTemplate> <igXamCombo:XamComboEditor x:Name="cboCategoryClass" Width="100" ItemsSource="{StaticResource CategoryClassOptionsList}" SelectedItem="{Binding CategoryClass, Mode=TwoWay, Converter={StaticResource CategoryClassConverter} ,ConverterParameter={StaticResource CategoryClassOptionsList}}" DisplayMemberPath="Text" IsEditable="False"> </igXamCombo:XamComboEditor> </DataTemplate> </igGrid:TemplateColumn.ItemTemplate> <igGrid:TemplateColumn.FilterEditorTemplate > <DataTemplate > <igXamCombo:XamComboEditor x:Name="cboCategoryClassF" Width="100" ItemsSource="{StaticResource CategoryClassOptionsList}" SelectedItem="{Binding Value, Mode=TwoWay, Converter={StaticResource CategoryClassConverter} ,ConverterParameter={StaticResource CategoryClassOptionsList}}" DisplayMemberPath="Text" IsEditable="False"> </igXamCombo:XamComboEditor> </DataTemplate> </igGrid:TemplateColumn.FilterEditorTemplate> <igGrid:TemplateColumn.FilterItemTemplate> <DataTemplate> <igXamCombo:XamComboEditor x:Name="cboCatClass" Width="100" ItemsSource="{StaticResource CategoryClassOptionsList}" SelectedItem="{Binding Value, Mode=TwoWay, Converter={StaticResource CategoryClassConverter} ,ConverterParameter={StaticResource CategoryClassOptionsList}}" DisplayMemberPath="Text" IsEditable="False"> </igXamCombo:XamComboEditor> </DataTemplate> </igGrid:TemplateColumn.FilterItemTemplate> </igGrid:TemplateColumn>
second column that should enable/disable unfortunately the call to the converter never gets called?????
<igGrid:TemplateColumn Key="VisitBased" IsFilterable="True" MinimumWidth="150" Width="Auto" IsResizable="True" IsReadOnly="True" FilterColumnSettings="{StaticResource FilterColumnSettingsBool}"> <igGrid:TemplateColumn.HeaderTemplate> <DataTemplate> <TextBlock Text="Basis" /> </DataTemplate> </igGrid:TemplateColumn.HeaderTemplate> <igGrid:TemplateColumn.ItemTemplate> <DataTemplate> <igXamCombo:XamComboEditor x:Name="cboVisitBased" Width="100" ItemsSource="{StaticResource VisitBasedOptionsList}" SelectedItem="{Binding VisitBased, Mode=TwoWay, Converter={StaticResource VisitBasedConverter} ,ConverterParameter={StaticResource VisitBasedOptionsList}}" DisplayMemberPath="Text" IsEnabled="{Binding CategoryClass,Converter={StaticResource VisitBasedConverterEnabled},Mode=TwoWay,UpdateSourceTrigger=PropertyChanged,BindsDirectlyToSource=True}" IsEditable="False"> </igXamCombo:XamComboEditor> </DataTemplate> </igGrid:TemplateColumn.ItemTemplate> <igGrid:TemplateColumn.FilterEditorTemplate > <DataTemplate > <igXamCombo:XamComboEditor x:Name="cboVisitBased" Width="100" ItemsSource="{StaticResource VisitBasedOptionsList}" SelectedItem="{Binding Value, Mode=TwoWay, Converter={StaticResource VisitBasedConverter} ,ConverterParameter={StaticResource VisitBasedOptionsList}}" DisplayMemberPath="Text" IsEditable="False"> </igXamCombo:XamComboEditor> </DataTemplate> </igGrid:TemplateColumn.FilterEditorTemplate> <igGrid:TemplateColumn.FilterItemTemplate> <DataTemplate> <igXamCombo:XamComboEditor x:Name="cboVisitBased" Width="100" ItemsSource="{StaticResource VisitBasedOptionsList}" SelectedItem="{Binding Value, Mode=TwoWay, Converter={StaticResource VisitBasedConverter} ,ConverterParameter={StaticResource VisitBasedOptionsList}}" DisplayMemberPath="Text" IsEditable="False"> </igXamCombo:XamComboEditor> </DataTemplate> </igGrid:TemplateColumn.FilterItemTemplate> </igGrid:TemplateColumn>-
Hello Nick,
Thank you for your post. I have been looking into it and I created a sample project for you with the functionality you want. Basically I bound the second TempalteColumn’s IsEnabled Property to the first one’s value. Please let me know if this helps you or you need further assistance on this matter.
this is a little basic and is very similar to what I already sent you in my sample xaml.
the changing value I need to test for is a string value that needs to run through a converter. My converter is not firing.
I wish my scenario was as simple as the example you here is the xaml and the 2 converters (the Categoryclass converter fires as expected, the Visitbased one does not
public class VisitBasedConverterEnabled:IValueConverter { public object Convert(object value, System.Type targetType, object parameter, CultureInfo culture) { if (value == null) return true; //Item template for filter bool val = false; string rst = value.ToString(); if (rst == "Hospital") val= false; else if (rst == "Provider") val= true; return val; } public object ConvertBack(object value, System.Type targetType, object parameter, CultureInfo culture) { return value; } }
public class CategoryClassConverter : IValueConverter { public object Convert(object value, System.Type targetType, object parameter, CultureInfo culture) { DropdownBoxOptions selectedItem = null; CategoryClassOptionsList values = parameter as CategoryClassOptionsList; if (values != null && value != null) { string selectedValue = (string)value; foreach (DropdownBoxOptions item in values) { if (item.Value != selectedValue) continue; selectedItem = item; break; } } return selectedItem; } public object ConvertBack(object value, System.Type targetType, object parameter, CultureInfo culture) { string result = ""; DropdownBoxOptions selectedType = value as DropdownBoxOptions; if (selectedType != null) result = selectedType.Value; return result; } }
private static VisitBasedCollection SetupEnum() { if (VisitBasedOptionsList.items == null) { VisitBasedOptionsList.items = new VisitBasedCollection(); DropdownBoxOptionsTypeBoolean item0 = ModelEntityBase.CreateAsNew<DropdownBoxOptionsTypeBoolean>(); item0.Text = "Episodic"; item0.Value = true; items.Add(item0); DropdownBoxOptionsTypeBoolean item1 = new DropdownBoxOptionsTypeBoolean(); item1.Text = "Patient"; item1.Value = false; items.Add(item1); }
private static CategoryClassBasedCollection SetupEnum() { if (CategoryClassOptionsList.items == null) { CategoryClassOptionsList.items = new CategoryClassBasedCollection(); DropdownBoxOptions item0 = ModelEntityBase.CreateAsNew<DropdownBoxOptions>(); item0.Text = "Hospital"; item0.Value = "Hospital"; items.Add(item0); DropdownBoxOptions item1 = new DropdownBoxOptions(); item1.Text = "Provider"; item1.Value = "Provider"; items.Add(item1); }
values for visitbased list
Actually I am all set I found my problem, the converter I wa susing was pointing to the wrong converter in my page resources
this
<local:VisitBasedConverterEnabled x:Key="VisitBasedConverterEnabled"/>
was actually this
<local:VisitBasedConverter x:Key="VisitBasedConverterEnabled"/>
so your example was in fact correct (and I was already doing that ) so we are all set
thanks
Thanks again.
