I have developed a web application. In my main page i have a webmenu & a WebTab. Inside the Webtab., i have 5 tabs in that WebTab, all of the tabs having a Webtree , Webimagebutton and a Webgrid.. Depending upon the tabs, the data's that i am showing will be different from each tabs. When i click "Save As" from "file" and save it as a HTML file, i can see that there are 5 different folder for each tab. I know that when we are using Infragistics, the corresponding Webresources are created for the javascript file for the webgrid , webtree , webmenu and webtab. These files are present in those 5 folder having the same script. The problems that i face are:
1) Why is it that the same Webresources are created in each of those folder eventhough they have the same content. i thought that only once will the WebResources will be called for the grid , tree , menu and tab.2) Because of this the Application is slow. Is there a way to avoid the problem?. Can i call the neccessary script only once throught the applications.
It's very urgent.. Please someone help me..
Thanks and Regards,Jollyguy
