570
Error on conversion from 7.3 to 11.1 version infragistics
Good morning,
I'been trying to get help and seems like you guys respond very well at the beginning and then just disappearing.
My company which I work for has a license but I downloaded version 11.1(i had 7.3 version) this is I need it to test my Web appication on Windows7 IE9 which will be installing throug out my company soon.
I change all assembly and references from v7.3 to v11.1 and worked fine on my local machine but when I deploy on development server I received error on very first infragistics control in the application:
 Parset Error Message:The base class includes the field 'UltraWebMenu1', but its type (Infragistics.WebUI.UltraWebNavigator.UltraWebMenu) is not compatible with the type of control (Infragistics.WebUI.UltraWebNavigator.UltraWebMenu).
Thanks so much for your help.
