140
using xamGrid edit cells to enter data
Hi, I have set up my xamGrid but cannot seem to even enter edit mode at this point.  I want to start off with an empty xamGrid, and have the user fill in the data, then save it to a database.  Here is xaml,
<ig:XamGrid HorizontalAlignment="Left" AutoGenerateColumns="False" Margin="45,334,0,0" Name="xamGrid1" VerticalAlignment="Top" Height="241" Width="302">
<ig:XamGrid.Columns>
<ig:UnboundColumn HeaderText="Book Code" Key="sBookCode" Width="100"></ig:UnboundColumn>
<ig:UnboundColumn HeaderText="Page Type" Key="sPageType" Width="100"></ig:UnboundColumn>
<ig:TextColumn HeaderText="Page Number" Key="sPageNumber" Width="100"></ig:TextColumn>
</ig:XamGrid.Columns>
<ig:XamGrid.AddNewRowSettings>
<ig:AddNewRowSettings AllowAddNewRow="Top" IsEnterKeyEditingEnabled="True" IsF2EditingEnabled="True"
IsMouseActionEditingEnabled="SingleClick" IsOnCellActiveEditingEnabled="True"></ig:AddNewRowSettings>
</ig:XamGrid.AddNewRowSettings>
<ig:XamGrid.EditingSettings>
<ig:EditingSettings AllowEditing="Cell" IsEnterKeyEditingEnabled="True" IsF2EditingEnabled="True" IsMouseActionEditingEnabled="SingleClick" IsOnCellActiveEditingEnabled="True" />
</ig:XamGrid.EditingSettings>
</ig:XamGrid>
When I single click on the row, nothing happens, cannot type anything.  Does the grid have to have a databinding or an itemsource to operate off of? F2 editing does not work, adding this code does nothing as well.
private void xamGrid1_CellClicked(object sender, Infragistics.Controls.Grids.CellClickedEventArgs e)
xamGrid1.EnterEditMode((Row)xamGrid1.ActiveCell.Row, xamGrid1.ActiveCell);
So I'm curious, what is required for the xamGrid to actually enter edit mode?  Also, I found a similar project with the following code and it worked great, just like I want it to work in mine.
private void gridKeywords_RowAdding(object sender, Infragistics.Controls.Grids.CancellableRowAddingEventArgs e)
PODRIAServicesLibrary.Web.Model.JobTag newRow = (PODRIAServicesLibrary.Web.Model.JobTag) e.Row.Data;
newRow.JobID =((PrintOnDemand.ViewModel.EditJobViewModel) gridKeywords.DataContext).CurrentJob.JobID;
((ViewModel.EditJobViewModel)gridKeywords.DataContext).CurrentJob.JobTags.Add(newRow);
e.Cancel = true;
The only difference I can see is the ViewModel have bindings set to the grid and creates a binding to the ID before editing, so that when the data is entered, it is already associated with an ID
