"hi, good day,
i have problems with my version of infragistics and internet explorer 10,
using a "webcombo", "webchooser" or "weblistbar, brand me an error openign the file , the error is
[FormatException: La cadena de entrada no tiene el formato correcto.]
System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal) +10164195 System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) +207 System.Convert.ToInt32(String value) +46 Infragistics.WebUI.WebCombo.WebCombo.getRenderer() +432 Infragistics.WebUI.WebCombo.WebCombo.get_Renderer() +45 Infragistics.WebUI.WebCombo.WebCombo.Render(HtmlTextWriter output) +100 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +240 System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +253 System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +87 System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +53 System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +240 System.Web.UI.Page.Render(HtmlTextWriter writer) +38 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4240
apparently is a problem with compatibility of internet explorer,
is there any way to fix this problem?
Thank you very much and greetings
Suryakumar,
We introduced support for IE11 with 2013 Volume 1 so you will need to upgrade to a later volume of the toolset for IE11 support. Please note that some of the controls that you are using have been retired and are not included in the later version. You can find more details on this in the NetAdvantage for ASP.NET Product Changes in 2011 Volume 2 blog post.
Let me know if you have any questions with this matter.
Infragistics 35 version=9.1.20091.2040 is not properly working in IE 11
Infragistics.WebUI.Misc Version=9.1.20091.2040Infragistics.WebUI.Shared Version=9.1.20091.2040Infragistics.WebUI.UltraWebCalcManager Version=9.1.20091.2040Infragistics.WebUI.UltraWebchart Version=9.1.20091.2040Infragistics.WebUI.UltraWebGrid Version=9.1.20091.2040Infragistics.WebUI.WebCombo Version=9.1.20091.2040Infragistics.WebUI.WebDataInput Version=9.1.20091.2040Infragistics.WebUI.WebHtmlEditor Version=9.1.20091.2040Infragistics.WebUI.Excel Version=9.1.20091.2040
This are the reference im using in VS 2008
can any one suggest me to solve this issue plz.
thanks for you reply , i figure out it . is Microsoft ajax.js caused it
Lily,
Do you have a sample with steps to reproduce that I can use to look into this?
Hi Alan
i update to 2238 version, and upgrade my web site by the UV tool. but the frame not working when i run the site in IE10. can help to fix it ?
Appreciate you looking on it
Thanks in advance.
