555
Web Drop Down
Dear All,
When I change My CSS Style for the Table, The Web Drop Down Control Size also changed, as Follows
Pls help me
Suhaib
  • 15979
    Hello Suhaib,
    This is an expected behavior. On the page “WebDropDown” control is rendered as group of HTML elements (mainly DIV’s and Tables) and if you apply styles to all such elements in your page these attributes will be applied to the dropdown control also.
    In order to avoid this you should create classes or id’s for all other tables and table elements and apply your CSS to them and not to all HTML elements of certain type on the page.
    Also if you use “!important” in some of the styles for dropdown surrounding elements you may consider removing it because it will be applied to all child elements regardless of other styles applied.
