650
swapping out data sources at runtime
I have a single XamReportViewer that I am using to bind to multiple different reports at runtime by using binding. These different reports have different numbers and types of data sources. I have tried to swap out the data sources in my code-behind by using the ReportProcessingRequested and ProcessingStarted however if i try to modify the ClientRenderSettings.DataSources during those calls it forces the event into a loop. Is there some other event that I should be using or is there some other method I should be using to swap out the data sources on a XamReportViewer? I can always use a template selector to pick a specific instance of a XamReportViewer template but then I would be forced to define separate templates for each report.
