405
images changing when node is expanded(urgent)
  when I load the tree with custom images, they are displaying correctly, but when I expand the node, the expanded node image is reset to some default minus image.
I am using netadvantage volume 2007 version 7.1
 here is the code. please help. I posted a question earlier, but there was no response.
 <ignav:ultrawebtree id="UltraWebTree1" runat="server" WebTreeTarget="HierarchicalTree" LoadOnDemand="ManualSmartCallbacks"
ImageDirectory="~/images/infragistics" OnDemandLoad="UltraWebTree1_DemandLoad" >
<Images>
<ExpandImage Url="ig_treeXPPlus.GIF" />
<CollapseImage Url="ig_treeXPMinus.GIF" />
</Images>
</ignav:ultrawebtree>
and the code-behind
protected void Page_Load(object sender, EventArgs e)
if (!IsPostBack)
Infragistics.WebUI.UltraWebNavigator.
Node node = UltraWebTree1.Nodes.Add("root");node.ShowExpand = true;
protected void UltraWebTree1_DemandLoad(object sender, WebTreeNodeEventArgs e)
Node node = e.Node.Nodes.Add("child1");
node = e.Node.Nodes.Add("child2");
