I am using a WebDropDown with a large dataset.
I set the SelectCommand of an SQLServer datasource at page load.
I set the webdropdown to EnableLoad on demand but it's not working.
ID="WebDropDownAluno" runat="server" Width="400px" AutoPostBack="False" ToolTip="Selecione o aluno" DataSourceID="SqlDataSourceAluno" DataKeyFields="Matrícula" ValueField="Matrícula" TextField="Nome" onselectionchanged="WebDropDownAluno_SelectionChanged" AutoPostBackFlags-ValueChanged="Off" AutoSelectOnMatch="False" AutoPostBackFlags-SelectionChanged="On" AutoFilterTimeoutMs="200" EnableAutoCompleteFirstMatch="False" EnableAutoFiltering="Server" EnableViewState="false" AutoFilterQueryType="Contains" AutoFilterResultSize="50" EnableLoadOnDemand="true"
At PageLoad:
SqlDataSourceAluno.ConnectionString = "some connection string"; SqlDataSourceAluno.SelectCommand = "some SQL text";
Hello Miranda,
I am still following your case. Have you been able to resolve you issue? Feel free to contact me if you have any additional questions regarding this matter.
I investigated the code snippet provided and everything seems correct.
Could you please provide some additional information in order to investigate the issue further:
1. Is your application throwing any kind of exception or it just does not load the data?
If it`s not loading the data what I can suggest is calling the DataBind method after setting the select command.
2. Which version of NetAdvantage are you using?
A small isolated sample where the issue is reproducibe would be highly appreciated.
