Hello
I'm using Reporting 2011 vol2. I am using a Silverlight client with server side rendering via a report service.
I have the above working fine in a clean visual studio solution however I cannot get it working in our main solution in which i want to implement reporting. I follow exactly to the same steps as my working clean solution but i am getting 'Cannot establish a connection with the report server' in the main solution.
I have compared web.configs and everything seems to be ok.
When i watch whats happening in fiddler I can see that it is actually connecting to the service. In my working solution can see there are 6 calls to the report service. When i watch in my main solution that is not working I see only 3 calls to the report service and the third is calling some sort of cancel process.
<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:a="http://www.w3.org/2005/08/addressing"> <s:Header> <a:Action s:mustUnderstand="1">http://tempuri.org/IReportProcessorService/Cancel</a:Action> <a:MessageID>urn:uuid:1be4a618-8d88-4a03-aa96-72b39b72370c</a:MessageID> <a:SequenceAcknowledgement> <a:ReplyTo>http://www.w3.org/2005/08/addressing/anonymous</a:ReplyTo> </a:SequenceAcknowledgement> <a:To s:mustUnderstand="1">http://localhost:52101/igReports/igReportService.svc</a:To> </s:Header> <s:Body> <Cancel xmlns="http://tempuri.org/"> <token>958e9b72-5e56-489d-a53a-d000132e6bc1</token> <cleanReportResources>true</cleanReportResources> </Cancel> </s:Body></s:Envelope>
Where as the working solution does this
<s:Header> <a:Action s:mustUnderstand="1">http://tempuri.org/IReportProcessorService/ProcessReport</a:Action> <a:MessageID>urn:uuid:3c634507-63b2-4b96-b270-af96333a59ae</a:MessageID> <a:SequenceAcknowledgement> <a:ReplyTo>http://www.w3.org/2005/08/addressing/anonymous</a:ReplyTo> </a:SequenceAcknowledgement> <a:To s:mustUnderstand="1">http://localhost:56279/ReportService1.svc</a:To> </s:Header> <s:Body> <ProcessReport xmlns="http://tempuri.org/"> <token>b609f79a-a3c6-4275-becf-f825534ac39c</token> <selectedParameterValues xmlns:b="http://schemas.microsoft.com/2003/10/Serialization/Arrays" xmlns:i="http://www.w3.org/2001/XMLSchema-instance"> </selectedParameterValues> <pageSettingsData i:nil="true" xmlns:b="http://schemas.datacontract.org/2004/07/Infragistics.Reports.Client" xmlns:i="http://www.w3.org/2001/XMLSchema-instance"> </pageSettingsData> </ProcessReport> </s:Body></s:Envelope>
Any help please?
Kevin
Hello Kevin,
Thanks again.
Thanks for your reply. I have got to the bottom of the problem. It was to do with the use of library caching in the Silverlight app resulting in some of the reporting assemblies being missing on the client. My test solution did not use library caching. Once that was resolved it all worked.
Thanks again,
Thank you for your post I have been looking into it and I can suggest you see this forum threads:
http://es.infragistics.com/community/forums/p/64680/327571.aspx#327571
and
http://es.infragistics.com/community/forums/p/77486/391134.aspx#391134
where similar issue are discussed.
Hope this helps you.
Bump! Anybody?
