Is there a way to simulate a click in UltraWebToolbar ?
I need to do this on code behind. The idea is like what you do to a server control where you can do.... Control.Focus()
I'm not sure if this is what you are trying to do but in our application (maybe someone else might) we sometimes simulate a click on the toolbar. If the user clicks the delete key for example we post back the page to do the delete.
To do this we use the following syntax.
__doPostBack("yourtoolbarID", "yourtoolbarID_item_0:UP") //0 indicates the button that is clicked.
and then handle the event in the onButtonClicked event in your serverside code.
I hope that helps.
Amy
in my experience, Infragistics support do not always answer emails.
crawler486 said:new forum look, same old ways. still no one is answering questions
Please remember that these forums area a peer-to-peer resource to share issues and ideas with other Infragistics users. If you require official support from Infragistics, please submit a support incident to Infragistics Developer Support from this page of our website.
Try looking at the Toolbars OnButtonClicked method.
http://help.infragistics.com/Help/NetAdvantage/NET/2007.3/CLR2.0/html/Infragistics2.WebUI.UltraWebToolbar.v7.3~Infragistics.WebUI.UltraWebToolbar.UltraWebToolbar~OnButtonClicked.html
Devin
