Hi all,
does anybody have any idea why whould the Next link from the pager not work after deployment? The refresh icon is shown forever, the second page is not fetched.
UltraWebGrid 11.1.20111.2020, Win7, IE 9
Thanks for any hint,
Anca
Hi guys,
we found the problem. The Compatibility Mode was active in IE9. It works as soon as we switch that off.
Hi Troy,
thanks for the help.
It is not easy to test this, because I do not have administrative rights on the server to deploy things there.
I really ment the question that way, like a brainstormig for the community: why shouldn't it work anymore after deployment? If anybody has any idea.... I probably do something wrong.
I mean, I see it work on the development PC and then, published on the server it doesn't work anymore.
I've looked at your example and the only thing I could think of is that we've used the version-free dlls. Are they somehow different?
Hi Anca,
I tested the paging behavior where .... e.Layout.Pager.StyleMode = Infragistics.WebUI.UltraWebGrid.PagerStyleMode.PrevNext;
Using the NetAdvantage 20111.2020 assemblies I have not been able to reproduce the behavior where the pager fails to fetch the next page.
I attached my test sample for your reference. Let me know if you are able to reproduce the behaviorwith my test sample. If so, let me know your precise steps to reproduce the problem. Or if you can modify my test sample such that it reproduces the behavior,s end back the modified version of my sample and I will look further into thsi issue for you.
Thanks!
I want to let you know that I have received your inquiry and will be looking into this issue for you. I will follow-up on this, on or before Thursday.
