i'm using map control(usa map) it is loading very slowly and one more problem when page loads some times map layer elements count is equal to zero and it is going to ideal state....
Thanks for Replying , I have solved that issue….
Thanks.
Hello Rajesh,
Thank you for your post. I have been looking into, but since this is not a known issue I cannot be completely sure what can cause this behavior, so if this is still an issue for you, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
