Is there a way to show a message when a report generates no results? Not because of an error but because there are simply no results in the database.
Thank you for your help.
Best Regards,
Geert De Vylder
Hi Leo,
Thank you very much for the answer. This works fine.
Greetings,
Geert
You should be able to do it using with the visibility of elements/sections. You can bind the visibility to a condition that uses a count.
Best,
Leo
