5124
Basic setup of nested HierarchicalDataTemplates
Hi IG Support,
I have attached a sample XamMenu bound to a 3-tier collection.  I am trying to use nested HierarchicalItemTemplates to display all three levels in the menu, however, only the first level is displayed.  If you run the sample, I expect "DHL" to expand to show the next level, but it does not.  Can someone take a quick look and point out my error in the markup?
Thanks!
Francis
PS - The irony is, I probably created just such a sample when I was in Dev Support. :)
XamMenuTest.zip
  • 27093
    Verified Answer
    Hello Francis,
    Really nice to see you. I looked into your project and you seem to have set the hierarchical ItemsSources a level lower each. Here is how it should be:
    <ig:XamMenu x:Name="PluginSelector"
                MenuOrientation="Vertical" ExpandOnHover="True"
                ItemsSource="{Binding Source={StaticResource PVM},Path=Carriers}">
        <ig:XamMenu.HierarchicalItemTemplate>
            <ig:HierarchicalDataTemplate ItemsSource="{Binding Path=Services}">
                <DataTemplate>
                    <TextBlock Text="{Binding Name}"/>
                </DataTemplate>
                <ig:HierarchicalDataTemplate.HierarchicalItemTemplate>
                    <ig:HierarchicalDataTemplate ItemsSource="{Binding Path=Rates}" > <!--temsSource="{Binding Path=Services}">-->
                        <DataTemplate>
                            <TextBlock Text="{Binding ServiceName}"/>
                        </DataTemplate>
                        <ig:HierarchicalDataTemplate.ItemTemplate>
                            <DataTemplate>
                                <Button Content="{Binding RateName}"
                                        Command="{Binding Path=LoadPluginCommand, Source={StaticResource PVM}}"
                                        CommandParameter="{Binding RelativeSource={RelativeSource FindAncestor, AncestorType=UserControl}}"
                                        BorderThickness="0" Background="White" />
                            </DataTemplate>
                        </ig:HierarchicalDataTemplate.ItemTemplate>
                    </ig:HierarchicalDataTemplate>
                </ig:HierarchicalDataTemplate.HierarchicalItemTemplate>
        </ig:XamMenu.HierarchicalItemTemplate>
    </ig:XamMenu>
    Let me know, if I can help with anything else.
