100
WebGrid not binding data when dynamically defining columns at runtime.
I'm having a problem binding a DataTable to a WebGrid.  This is the setup:
 There's a button on the page that causes a postback.  And during the postback in the event method, I dynamically define each UltraWebColumn and then add each column to the WebGrid.  Then after each column is defined, I assign the datasource to the DataTable and then execute the WebGrid.DataBind() method to bind.
 So, this is the issue.  When I click the button for the first time, no data is rendered to the page.  But, the WebGrid will render data when the button is clicked a second time and any other time after.  But when I clear the webgrid at runtime then click the button to render the grid, no data is rendered again until I click the the button a second time.
 Does anyone have an idea why this might be happening?  Thanks.
