Hi, I have an WebDataMenu attached to a webhierarchicacl data source, in development it shows all elements, deployed in the server (win 2008), the menu do not show any items, I'm using the same database in develope and in the server, so I can not figure out what is going on, why I see all in develope and nothing in the server?
Hi losoriomx,
Is it possible for you to attach a small sample, reproducing this behavior, in order to be able to investigate it?
Also, I could suggest you to try upgrading your controls to the latest version.
sorry for the time to response, the problem occurs in the development machine and in the production server, I have tried deleting and using a new data menu and the problem keeps on, I have destroyed the complete page and created a new one that worked 2 weeks and now it is not loading the data again, please give some ideas
Please let me know if you still need assistance with the matter.
This is very strange issue. I would suggest you to make sure you have all required resources deployed on your server. Here you can find some useful articles on the matter - http://help.infragistics.com/NetAdvantage/ASPNET/2012.1/CLR4.0/?page=Web_Deploying_Your_Application.html.
Hope this helps.
