110
Formating and charting of the report
Hello!
I encountered the following today while evaluating your product.
1) I am missing a stack panel diagramm. Are there any plans to include this type?
2) As the stack panel diagramm is not possible, I wanted to add a "Column chart" type and add two columns. The columns should visualize count(<Datafield1>) and count(<Datafield2>). Am I correct that the functions Count, Sum, Max, ... are not supported in the chart types?
3) While trying different options to achieve my goals, I added labels to the report footer. Opening the Label Text Assistant and selecting the "Sum()" function, I then inserted (double clicked) the variable from my data source. The Assistant made the following expression "=Sum(First(Fields.CheckNotPassedIndicator, DataSources.MyDataSource)).
Why does the assistant insert the "First()" function when I double click on a variable of my data source?
I removed the "First()" function to get the formulas running correct.
If I insert "=Count(Fields.CheckNotPassedIndicator, DataSources.MyDataSource)" at the Label Text Assistant I get the following error message:
"Expression contains parsing error(s) Unable to resolve expression type, Parameter count mismatch at ().F<Id<Count>>(Ctx<Fields>.Id<CheckNotPassedIndicator>,Ctx<DataSources>.Id<MyDataSource>)"
Making a Sum() is possible but Count() on the same variable is not possible although the variable has the type int. What must be changed to get the "Count()" functioning?
4) Depending on a field of the row, the table row should be hidden (row height = 0). If the visibility of the row is set to the field value, the row is not visible but consuming space on the report. This leads to a "fragmented" detail section.
5) I do not want a page break between the detail section and the report footer which contains the sum() and count() functions. In the detail section the InsertPageBreakAfter is set to "False". How can I remove/disable the page break?
6) Is there a possibility to fill the datasource while designing the report? If i change the width of a label , I do not want to start the complete solution to check if the variable could be displayed without a line break.
Thanks for your information
Best Regards
Alex
