Greerings, dear support team.I would like to use AutoSalesDashboard or InfraAIR sample app like a basis for my solution (because of its convinient structure and nice UI).So, i'm trying to change assemblies to SL2012.1 version in it (to avoid diplaying of a trial message). I change references of the projects and dll files in the solution folders. Then, i'm trying to rebuild solution and run it. But when the application loads I get error 2103 in my browser:SCRIPT5022: Unhandled Error in Silverlight ApplicationCode: 2103 Category: InitializeError Message: Invalid or malformed application: Check manifestAm i doing it wrong? How should I correctly replace assemblies in the solution?Is it (using InfraAIR like a base for my app) a good practice on the whole?P.S. I'm using silverlight 5, IG SL 2012.1 components and 2010 Visual Studio.Thank you in advance!
Hello Eugene,
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
I found two links which can be useful: http://www.benday.com/2010/07/16/error-2103-unhandled-error-in-silverlight-application/ and http://www.codeproject.com/Tips/393604/Error-2103-Unhandled-Error-in-Silverlight-Applicat.
There is nothing special in the replacement of references - just delete old references and add the new 12.1(they should be licensed, if you don't want the trial message in the bottom right corner).
Anastas
