I wanted to generate a pivot view using OLAP flat data source. The pivot should look like attached image. I don't know how to add measures added in last 2 columns ('Internet Ratio to Parent Product' and 'Internet Ratio to All Products'). The pivot view shown in attached image was generated using http://es.infragistics.com/products/silverlight/sample/pivot-grid/#/calculated-members. The only difference is, I have the data in ObservableCollection<Sales> and not pulledusing any OLAP cube. So, I am wondering how to add last 2 measures. Any sample solution/code snippet is what I'm looking for...
Thanks in advance...
Rohan Bhat
Hello Rohan,
I am just checking if you got this worked out, or you still require any assistance, or clarification on the matter.
If this is what you were looking for please verify the answer so it helps other users as well.
I have been looking into this and I can suggest looking into this sample project illustrating how you can create FlatData Aggregators: http://es.infragistics.com/products/silverlight/sample/pivot-grid/#/flatdata-aggregators and a link from our online documentation showing how you can create custom aggregators. Also you might want to read through this forum thread that discusses a similar issue: http://es.infragistics.com/community/forums/t/48022.aspx
Please let me know, if you require any further clarification on the matter.
