I have now introduced a new column with hyperlink cell values. The problem is clicking on the hyperlink fires the RowEditTemplate, the page does not navigate away as you would expect it to.
Rob
I see that this post is from 2010 -- and still unanswered. I have the same question. I'm new to the Infragisitics tool set, was hoping to get up an running quickly, but even the simplest things are hard to do and the documentation is immensely frustrating. I've spent hours trying to figure out how to define a hyperlink field in a web grid. Is it possible?
Did you ever get an answer to how to do a hyperlinkfield ? I am trying to do the same exact thing.
Irwin
Amol said: hi, Somewhat related to this how I can implement similar facilty like following in the UltraWebGrid as of .Net default GridView Control. <columns> <asp:HyperLinkField DataNavigateUrlFields="id,PermissionCount,RoleName" DataNavigateUrlFormatString="AddRole.aspx?id={0}&pcnt={1}&rn m={2}" HeaderText="Role Name" DataTextField="RoleName" > <HeaderStyle HorizontalAlign="Center" CssClass="Form_bold" /> <ItemStyle HorizontalAlign="left"/> <HeaderStyle HorizontalAlign="center" /> </asp:HyperLinkField> <columns> Thanks,
hi,
<columns>
<asp:HyperLinkField
m={2}"
It seems to me, that the problem occurswhen the columns are added programatically. The AllowUpdate = No seems to have no effect at all, when the column is added dynamic. It still fires the RowEditTemplate. Can you reproduce this behavior?
