275
LoadOnDemand and Postback
I have a heirarchial grid that I would like to use LoadOnDemand with but I can't seem to get it to work. When I click on a button which posts back the form and changes the rows in the datasource then the second band doesn't appear.
The bands and columns are created in the aspx page and AutoGenerateColumns is set to false.
Here is a simplified version of my code
 Sub Page_Load
if not myGrid.IsXmlHttpRequest then
'-- I connect to the database. I dispose in the unload event.
End if
End Sub
sub btnSearch_click(ByVal sender ....
    dim ds as dataset
    ds = doSearch(txtSearch.text) 'In this function I retrieve the dataset from the database and set the datarelations.
    myGrid.datasource = ds
end sub
Sub myGrid_InitializeLayout
    myGrid.Bands(0).DataKeyField = "ID"
    myGrid.Bands(1).DataKeyField = "ID, ID2"
End Sub
Sub myGrid_InitializeDataSource
    if myGrid.IsXmlHttpRequest then
       'Connect to database. If this is called then I dispose in the pre_render event
        dim ds as dataset
        myGrid.DataSource = ds
    end if
End Sub
I'm not sure what is going wrong but in the InitializeRow event the second band doesn't seem to exist. Any Ideas?
  • 275
    I figured it out myself. In case anyone has the same problem this is what fixed it.
    In the InitializeDataSource event I put the following.
    if myGrid.isXmlHttpRequest then
        dim ds as dataset
    else
         e.cancel = true
    end if
    I guess that prevents further processing which was clearing the other bands and column info specified in the aspx page.
     Amy
