205
UltraWebGrid CSS and CSSClass is not working.
 After upgradding from6.3 to 7.x and now 8.1 clr 3.5 The CSS Classes we had set on the Grids no longer work for new grids.
 If I leave an old version grid on the page the CSS items that are set in the grids properties for ( row, alt row, selected row, etc..) all work fine.
But the new version of the grids in both version 7.x and 8.1 do not work.
I have tried setting the properties manually and have received a sample from Infragistics with a video indicating that it works for them but I have
15 developers that the same code sent to me will not work for them
Ive tried setting ti manually like so
        UltraWebGrid1.DisplayLayout.OptimizeCSSClassNamesOutput = Infragistics.WebUI.Shared.DefaultableBoolean.True
and false on the above line
        UltraWebGrid1.DisplayLayout.RowStyleDefault.CssClass = "CSSRow"
        UltraWebGrid1.DisplayLayout.HeaderStyleDefault.CssClass = "CSSHeader"
What Gives? Why does Infragistics have to break things that work in previous versions
Larry
