Here's what I'm calling unexpected behaviour:
A date cell is initially loaded from the CLR source, using databinding, with for examplle: 8/2/2012. I select the cell and no matter what I key in, 6/1/2012 for example, when focus moves away from the cell the value reverts back to its original value, 8/2/2012 for example. However, if I use the drop down calendar, DatePicker, and select a date, the selected date is displayed and also remains when focus moves away from the cell.
The application has other XamGrid's with DateColumns that work as I expect.
I'd appreciate any suggestions as to why this is happening and ways to troubleshoot it further. Here is the Xaml (Snippet):
<ig:XamGrid Grid.Row="1" HorizontalAlignment="Stretch" Margin="0,0,0,0" Name="propertiesGrid" VerticalAlignment="Stretch" AutoGenerateColumns="False" ItemsSource="{Binding}" HeaderRowHeight="23" > <ig:XamGrid.EditingSettings> <ig:EditingSettings AllowEditing="Cell" IsMouseActionEditingEnabled="SingleClick" /> </ig:XamGrid.EditingSettings> <ig:XamGrid.Columns> <ig:DateColumn Key="Data.BeginDate" HeaderText="Begin Date" /> <ig:DateColumn Key="Data.EndDate" HeaderText="End Date" /> </ig:XamGrid.Columns></ig:XamGrid>
No worries at all. Happens to all of us. I'm glad you were able to solve your issue.
It was a stupid programmer mistake. Problem solved. Sorry for taking your time.
Hi jgreene274,
So this XamGrid is the only one who's DateColumns behave this way? Does this XamGrid have settings that differ from the other XamGrids in your application? Do you have any styles that target the XamDateTimeInput control?
