760
NullReferenceException when setting OlapAxis DataSource
When setting the DataSource of the OlapAxis, it throws NullReferenceException.
Here is the code snippet that causes the exception:
                    var numericYAxis= new NumericYAxis()
                                              LabelSettings = new AxisLabelSettings()
        Extent = 55,
        Location = AxisLabelsLocation.OutsideLeft,
        IsHitTestVisible = true
                    DataChart.Axes.Add(numericYAxis);
                    OlapXAxis olapXAxis = new OlapXAxis();
                    olapXAxis.YAxis = numericYAxis;
                    olapXAxis.Label = "{Label}";
                    olapXAxis.OlapAxisSource = OlapAxisSource.Rows;
                    olapXAxis.LabelSettings = new AxisLabelSettings();
                    olapXAxis.LabelSettings.Extent = 35;
                    olapXAxis.LabelSettings.Location = AxisLabelsLocation.OutsideBottom;
                    olapXAxis.DataSource = chartViewModel.OlapViewModel;//Note:OlapViewModel is not null
   at Infragistics.Controls.Charts.OlapXAxis.LayoutArranged()
   at Infragistics.Controls.Charts.OlapAxis.ArrangeLayoutInternal()
   at Infragistics.Controls.Charts.OlapAxis.DataSourceChanged(DependencyObject obj, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.RaisePropertyChangeNotifications(DependencyProperty dp, Object oldValue, Object newValue)
   at System.Windows.DependencyObject.UpdateEffectiveValue(DependencyProperty property, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, ValueOperation operation)
   at System.Windows.DependencyObject.SetValueInternal(DependencyProperty dp, Object value, Boolean allowReadOnlySet, Boolean isBindingInStyleSetter)
   at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value)
   at Infragistics.Controls.Charts.OlapAxis.set_DataSource(IOlapViewModel value)
   at GoIT.Dashboard.Infrastructure.Controls.Charts.DataChartControl.ResolveXAxis(IChartViewModel chartViewModel)
Is there any way how to fix it?
Thank you
