4970
Dependency between XamDataTree and DragDrop?
My SL 5 app use XamDataTree. It is okay when I run it on one computer which install Infrisgistics 2012.
But on another computer which does not install Infrisgistics 2012 but have all those assemblies referenced by app, I got the error when run the app:
   at MS.Internal.CoreInvokeHandler.InvokeEventHandler(UInt32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
   at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName, UInt32 flags)
Caused by: The invocation of the constructor on type 'Infragistics.Controls.Menus.XamDataTree' that matches the specified binding constraints threw an exception. [Line: 26 Position: 60]
   at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
when check exception in debug mode and got more info which said it ask for InfrisgisticsSL5.DrapDrop.V21.1, but I do not use any dragdrop function in the app.
so question: there is a Dependency between XamDataTree and DragDrop?
