85
Will report designer work with MySql?
I have attempted to connect the report designer to a MySql database but the "Data Source Configuration Wizard" just exists.
I can get the new connection setup and tested correctly and get the list of Tables and Views. If I pick a table, view, or enter a select statement, the window just closes.  In the case of a select statement, I get a "Error while running query, please verify that the syntax of the query is correct".
Should the report designer be able to work with MySql?
John
