Hi there
We are using the WebToolbar control inside an UpdatePanel, that has a ProgressPanel attached to it.
However when i select a button from the WebToolbar that i s inside the panel we are not seeing the progress panel.
any suggestions how i can get it to display
Cheers
JB
Hello Jonathan,Please let me know what is your progress with the issue have you manage to resolve it?
Hello Jonathan,I tested the attached sample with the latest build for 9.2 under IE 8 and it did not provided the described from you issue. If you are using another build than the latest service release please let me know so I can test and tell you what are the results.
Hello.
Thanks for your reply, however your example bears no resemblance to my scenario.
The browser I am using is IE8.
I have an updatepanel with a ToolBar control in it, it is the events from the toolbar control that do not seem to trigger the update panel progress, other events from a grid i have on hte same page to trigger the update panel progress.
I am currently using the 9.2 controls.
cheers
Hello Jonathan,I have created a sample based on your scenario and i was not able to reproduce the issue you are facing. Please review the sample and modify it . When the updating is invoked a lable with red background is shown for 2 seconds. If your version is different please let me know. It would also be helpfull if you share what browsers you are using to reproduce the issue.
