1. Create a class as:
public class Item: Object { public int ID { get; set; } public string Name { get; set; } public override bool Equals(System.Object obj) { // If parameter is null return false. if (obj == null) { return false; } // If parameter cannot be cast to Point return false. Item i = obj as Item; if ((System.Object)i == null) { return false; } // Return true if the fields match: return ( ID== i.ID); } public override int GetHashCode() { return ID; } }
2. Get data from wcf ria service:
MyItems = (from b in this._result select new Item{ Name = b.Name, ID = b.ID }).Distinct();
3. set ItemSource for XamComboEditor:
this.MyCombo.ItemsSource = vm.MyItems;
4. Xaml for XamComboEditor is:
<ig:XamComboEditor x:Name="MyCombo" IsEditable="True" AllowFiltering="True" AutoComplete="True" DisplayMemberPath="Name" SelectionChanged="MyCombo_SelectionChanged" />
then run the app and change selected item from XamComboEditor, but event MyCombo_SelectionChanged is never fired.
How to resolve this problem?
Do you have any other questions on this matter?
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
Hello benjaminswitzer,
For firing SelectionChanged event I have attached a sample.
