hi,
how to bind the xamMap with wcf datasource? i need some example on how to do this..
assume my xamMap or shapefile already work..however i need the xamMap to retrieve data from wcf and display it whenever i hover through the map..
pls..asap..
Hi irul,
Please take a look at the following sample:
http://samples.infragistics.com/sllob/map/sl/#/binding-to-wcf-data
Hope that helps,Milana Zhileva
