845
BusyIndicator not displaying when view is displayed inside a XamDialogWindow
We have the following view:
<UserControl x:Class="DetailedSalesView" ...
  <Grid x:Name="LayoutRoot">
    <toolkit:BusyIndicator x:Name="activityControl"
IsBusy="{Binding IsBusy}"
BusyContent="{Binding}" >
<Grid> The rest of the control </Grid> </toolkit:BusyIndicator> </Grid> </UserControl>
When this is instantiated normally the busy indicator appears as expected. The view model implements `INotifyPropertyChanged` and has the property `IsBusy` which gets set at the appropriate places.
We are trying to display this same view in a XamDialogWindow and everything is working except for the BusyIndicator.
The code we have is:
    this._eventAggregator = container.Resolve<IEventAggregator>();
Where `container` is an `IUnityContainer`
    var childViewModel = new DetailedSalesVM(dataService, _eventAggregator);
    var childView = new DetailedSalesView(_eventAggregator, childViewModel);
    var window = new XamDialogWindow
        Width = 800,
        Height = 600,
        Content = childView,
        StartupPosition = StartupPosition.Center,
        Header = headerText
    parent.Children.Add(window);
Where `dataService` is a class that implements the RIAServices connection to the database, and `parent` is the `UIElement` we wish to display the dialog window in.
The view populates correctly and the `IsBusy` property on the view model is set as expected, but the `BusyIndicator` just doesn't display.
What are we missing?
  • 138253
    Verified Answer
    Hello Chris,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I modified your sample, so now it works as you want. Basically I used Dispatcher to set the Content of the XamDialogWindow, because the BusyIndicator renders faster and it seems like that it remains below the Window.
  • 845
    I have created a simple project that reproduces this issue. I've uploaded the file to my Google Drive folder:
    https://docs.google.com/open?id=0ByA9Ma2avsZqaXZlci1vTjNrcE0
    It just consists of a main page with a single button that opens the child window whose contents (another button) are wrapped in a busy indicator. In this version the busy indicator is permanently on and you can see that that the button is greyed out but the busy indicator is not visible.
  • 845
    I've done some further investigation and have found the following:
    • The notification of the `IsBusy` property changing value is definitely getting to the view.
    • If I hard code the `BusyIndicator` to be `Busy` it still doesn't appear, but the contents of the view (in this case a `XamGrid` are no longer selectable (I can't select the grid cells or row).
    • Swapping the `XamGrid` for other, simpler, controls such as a `TextBlock` or `Button` shows exactly the same behaviour.
    • In fact careful examination reveals that the content is in fact disabled during the period when the `BusyIndicator` should be visible.
    • We're using a custom style for the `BusyIndicator` but even when I remove this I get the same behaviour.
    This leads me to think that the `BusyIndicator` is getting shown but is for some reason completely transparent.
