290
Olap Axis: Tooltips;
I'm doing a demo for the customer using NetAdventage for Silverlight 12.1 . During working with Olap Axis I encountered a difficulty setting a tool tip; I need to display {Series Title} : {Value} on mouse over series.
I tried to create a simple binding within  SeriesCreating event handler, but it does not work. Here is the code I use to create the binding:
            TextBlock textBlock = new TextBlock();
            textBlock.SetBinding(TextBlock.TextProperty, new Binding("Item.Cell.Value") { Source = e.Series //What should be the source for the binding?
I know that OLAP Axis feature is still CTP, but  I would like to ask you if it is feasible to achieve what I need with the current version.
Thanks in advance,
Alex
  • 995
    Verified Answer
    Hi Alex,
    The data context of the DataChart tooltip is set to a object of the Infragistics.Controls.Charts.DataContext type, so you do not need to set the Source of the Binding.
    I would suggest you try the following:
    private void OlapAxis_SeriesCreating(object sender, SeriesCreatingEventArgs e)
                TextBlock titleTextBlock = new TextBlock();
                Binding seriesTitleBinding = new Binding("Series.Title");
                titleTextBlock.SetBinding(TextBlock.TextProperty, seriesTitleBinding);
                TextBlock valueTextBlock = new TextBlock();
                Binding cellValueBinding = new Binding(string.Format("Item.{0}", e.SeriesInfo.Title));
                cellValueBinding.StringFormat = ": {0}";
                valueTextBlock.SetBinding(TextBlock.TextProperty, cellValueBinding);
                StackPanel sp = new StackPanel();
                sp.Orientation = Orientation.Horizontal;
                sp.Children.Add(titleTextBlock);
                sp.Children.Add(valueTextBlock);
                e.Series.ToolTip = sp;
    Hope this helps.
    Philip
