4970
XamGrid not working propertly in Modal popup with SL 5.
I migrated an SL 4 app to SL 5 app and migrated Infrigistics product to 2012. then something wrong with XamGrid. it is working fine in SL 4 with Infrigistics product to 2011.
Here is my case:
 A XamGrid with double clicked event to choose the selected row.
In SL 5, the popup with XamGrid has some problems:
1. Extremely slowly and the app looks like frozen
2. No response for click/double click on the XamGrid.
Here is my pseudo code:
 XamDialogWindow XDW = new XamDialogWindow() {IsModal=true};
 XDW.Content = new SearchLookUp();    //SearchLookUp include a XamGrid which load data from DB with wcf ria service
 ((Canvas)this.FindName("PopupBase")).Children.Add(XDW);
 XDW.ShowAndFocus();
here is xaml for usercontrol SearchLookUp:
    <Grid x:Name="LayoutRoot" Background="White" VerticalAlignment="Stretch"  HorizontalAlignment="Left">
    <controlsToolkit:BusyIndicator HorizontalAlignment="Center" VerticalAlignment="Center" x:Name="busyIndicator" IsBusy="{Binding IsBusy}">
            <Grid>
                <Grid.RowDefinitions>
                    <RowDefinition Height="Auto" />
                    <RowDefinition Height="*" MinHeight="400" />
                </Grid.RowDefinitions>
                <view:SearchEngagerAdvance Grid.Row="0" x:Name="SearchEngagerAdvanceV" HorizontalAlignment="Stretch" DataContext="{Binding Filter,Mode=TwoWay}"/>
                <ig:XamGrid Grid.Row="1"
                          ItemsSource="{Binding DataList,Mode=TwoWay}"
                          RowSelectorClicked="xamGrid_RowSelectorClicked"
                          CellDoubleClicked="grdEngager_CellDoubleClicked"
              AutoGenerateColumns="False" >
  <ig:XamGrid.RowSelectorSettings>
        <ig:RowSelectorSettings x:Name="rowSelectorSettings" Visibility="Visible" />
    </ig:XamGrid.RowSelectorSettings>
    <ig:XamGrid.FilteringSettings>
        <ig:FilteringSettings AllowFiltering="FilterRowTop" IsMouseActionEditingEnabled="SingleClick" />
    </ig:XamGrid.FilteringSettings>
    <ig:XamGrid.PagerSettings>
        <ig:PagerSettings AllowPaging="top"  Style="{StaticResource AmsPager}" />
    </ig:XamGrid.PagerSettings>
    <ig:XamGrid.ClipboardSettings>
        <ig:ClipboardSettings AllowCopy="True" AllowPaste="True"/>
    </ig:XamGrid.ClipboardSettings>
    <ig:XamGrid.SortingSettings>
        <ig:SortingSettings AllowMultipleColumnSorting="True" />
    </ig:XamGrid.SortingSettings>
    <ig:XamGrid.ColumnMovingSettings>
        <ig:ColumnMovingSettings AllowColumnMoving="Indicator"/>
    </ig:XamGrid.ColumnMovingSettings>
    <ig:XamGrid.SelectionSettings>
        <ig:SelectionSettings CellSelection="Multiple" ColumnSelection="Multiple" RowSelection="Multiple" CellClickAction="SelectRow" />
    </ig:XamGrid.SelectionSettings>
    <ig:XamGrid.ColumnChooserSettings>
        <ig:ColumnChooserSettings AllowHideColumnIcon="True" AllowHiddenColumnIndicator="True"></ig:ColumnChooserSettings>
    </ig:XamGrid.ColumnChooserSettings>
    <ig:XamGrid.ColumnResizingSettings>
        <ig:ColumnResizingSettings AllowColumnResizing="Indicator" AllowMultipleColumnResize="True" AllowCellAreaResizing="True" AllowDoubleClickToSize="True" />
    </ig:XamGrid.ColumnResizingSettings>
    <ig:XamGrid.ConditionalFormattingSettings>
        <ig:ConditionalFormattingSettings AllowConditionalFormatting="True" />
    </ig:XamGrid.ConditionalFormattingSettings>
                    <ig:XamGrid.Columns>
                    </ig:XamGrid.Columns>
                </AMSCommon:AMSXamGridControl>
            </Grid>
        </controlsToolkit:BusyIndicator>
    </Grid>
How to resolve this problem?
  • 12875
    Suggested Answer
    I built a small sample based on the code you provided using SL4 2011.2, pointing to Silverlight 4 and  added Debug writeline statements to the two events, xamGrid_RowSelectorClicked and grdEngager_CellDoubleClicked.
    After running the app for the purposes of comparison, I upgraded the app to Silverlight 5 and used our product release version 2012.1 Version Utility and upgraded the solution.
    The event both seem to fire appropriately with 2011.2 and 2012.1.
    A couple of variations from your description are that I did not implement RIA services for the data.  And I am also not aware of the ShowAndFocus method for the xamDialogWindow     I don’t have the AmsPager style that you reference in the xaml or the SearchEngagerAdvanceV view or the busyIndicator.
    You’ll also see that after providing my own datasource I tried to see the difference between allowing AutoGenerateColumns set to true and to false, but I could  not detect any difference in the samples.  I used the Visual Studio Performance Wizard to compare the two versions compiled with the separate product version but saw no difference.
    I am to attaching my sample 2012.1 version.
    If you can modify my sample to make it more like your application, I can retest and see if I can duplicate the behavior.    Also if you could please let me know what specific version of 2011.2 and 2012.1 you were using.
    SL_xamGrid_migrate 121.zip
