Hallo,
I create a project with an "infragistics Report server" and I can't select the element "infragistics Report server" under "Infragistics > Reporting".
What's wrong?
I have install the NetAdvantage 12.1.
Regards
Thoams
Hi,m using report object to generating print preview for xamdatagrid , however if the grid contains data in bulk,preview generation gets very slow and takes quite a long time.is there any solution or work aorund to make its performance better? i am working on wpf application
Sehr gut! :)
If you have any other question, please let me know.
Simon
Hallo Simon,
I've resolved the problem.
In the project properties I've changed the target framework from "Net Framework 4 Client Profile" to "Net Framework 4". After this change I can see the element.
Thanks!
Thomas
Hallo Thomas!
Can you tell me how did you upgrade or how did you install Reporting?
It seems to be an installation issue.
Did you close all the Visual Studio instances before installing? Did you upgrade from 11.2?
thanks!
