455
StackedBarChart Y-Axis Label & Orientation
Hi Can some one tell me how to get the Labels on the Y-axis to show more that just the first one ?
and also if possible transpose the columns so that they are going up vertically instead of horizontally
i am using a stackedbarchart and there does not seem to be a way to Orient it to flip it vertically, a sample code would be very helpful, i have looked through all the silverlight infragistics sample and there does not appear to be anything adequate..
here is a picture :
 as you can see only the first vertical label witha green background is shown..it should be a whole range all the way to the top on the Y axis... thanks in advance
Shadow
  • 138253
    I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
  • 138253
    Thank you for your post. I have been looking into it and I can suggest you use StackedColumn Series instead of StackedBar ones, which are vertically oriented. Please let me know if this helps you or you need further assistance on this matter.
