Due to issues with using non-scaled bubbles within the xamDataChart I have been successfully using the RadiusScale property to set min/max sizes for chart bubbles. This works fine for a single series, but for multiple series there is no correlation between the sizes of the bubbles in different series. I have the situation where a user has created a chart with 10 series, each with only a single data point in each series. In this case all the bubbles are the same size as they data sources for each series are not linked by the chart control.
Is there a way I can keep the min/max bubble sizes produced by the RadiusScale property and ensure the bubbles across multiple series are all scaled in relation to each other?
Chris
After the research done the discussed functionality has been determined to be a new Product Idea. I have sent your feature request directly to our product management team. Our product team chooses new feature requests for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time. Your reference number for this product idea is PI12050069.
If you would like to follow up on your feature request at a later point, you may contact Developer Support management via email. Please include the reference number of your feature request in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
Sincerely,
Ekaterina
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
If you could log this as a new feature that would be helpful.
In the meantime I will try and scale the bubble radius values across series manually, as I really need this functionality ASAP.
Kind Regards,
I have been looking into your question and the RadiusScale property is independent for all the Series, there is no correlation between the different series. What I can do for you is to log a new Product Idea of creating a property for the whole Series collection, if you would like to.
I will be looking forward to receive some feedback from you regarding the discussed matter.
