620
Parameter Label
I have a parameter in my report with the following values
Value = 0, Label = Daily
Value = 1, Label = Weekly
Value = 2, Label = Monthly
I want to add a label to the report header for the Search Criteria and if I do the following
="Report Type " + Parameters.C_Options
I get the value of the parameter not the label, I want it to say "Report Type Daily" not "Report Type 0"
David.
  • 550
    Suggested Answer
    Hello David,
    Regrettably currently isn't possible to access the Label value of the parameter. You can access just the value of the parameter.
    As a workaround you can use the following expression:
    = "Report Type " + if (C_Options = 0, "Daily", if(C_Options = 1, "Weekly", "Monthly"))
    Hope it helps!
    Please let me know if you require any further clarification on the matter.
    Normal 0 false false false EN-US X-NONE X-NONE
