440
Bind the entire row object to a single column
I am using xamwebgrid. In the grid I want to show an image column so I am using the TemplateColumn and applying datatemplate that contains four images. Now based on two properties in my Object that is bound to the row, I want to show only two of the images.
I can use a value converter to show/hide the images. The only problem is I can bind my column to only one property in my Object. So in the valueconverter I can pass only one property as multibinding is not present in silverlight.
Is there anyway I can bind my entire Object out of the List to one column. That way I can write all the show/hide logic in a single valueconverter.
  • 6912
    Suggested Answer
    You can pass the entire object to the value converter like that:
    <ig:XamGrid>
    	<ig:XamGrid.Resources>
    		<local:MyConv x:Key="MyConv" />
    	</ig:XamGrid.Resources>
    	<ig:XamGrid.Columns>
    		<ig:TemplateColumn Key="MyColumnKey">
    			<ig:TemplateColumn.ItemTemplate>
    				<DataTemplate>
    					<Image ... other settings ...
    						   Visibility="{Binding Converter={StaticResource MyConv}}" />
    				</DataTemplate>
    			</ig:TemplateColumn.ItemTemplate>
    		</ig:TemplateColumn>
    	</ig:XamGrid.Columns>
    public class MyConv : IValueConverter
        public object Convert(object value, Type targetType, object parameter, CultureInfo culture)
            return [... condition ...] ? Visibility.Visible : Visibility.Collapsed;
        public object ConvertBack(object value, Type targetType, object parameter, CultureInfo culture)
            return DependencyProperty.UnsetValue;
    HTH
