Please find attached a small sample project. The project uses version 11.2.20112.2068 of Infragistics DV.
My problem is that when using the pivotgrid, and hiding all totals rows, then clicking the bottom visible cell makes the grid scroll to the top. We often want to hide the sum rows (and columns) because the data displayed makes no sence when summarized (for instance frequences).
When running the attached project a pivotgrid is displayed with one column and a number of rows (two levels). Expand some of the levels and scroll down the list, then select the bottom visible cell, and everything is fine. If the cell is not completely visible it is also scrolled into view.
Now, check the checkbox at the upper left corner (Hide sum rows). If you now select the bottom visible row the grid will scroll to the top. Quite annoying.
Any idea of why this is happening? If I do something wrong when hiding the totals rows, or if I should do something different/additional, please advice so
Hi Mikael,
I have investigated your issue, and I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 104662. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
I have created a private case for you so that you may be updated automatically when a resolution is available. The case number is CAS-86531-CK88LZ.
Using your sample I was able to reproduce the behavior you described. I agree this does seem rather annoying and I'm not quite sure what the cause is at the moment. I'm going to research this further and I'll update you early next week.
