I need to perform printing without any priner dialog. I'm loading printer names into combobox. I'd like to specify copies quantity and make prints in total silent mode. Is it possible ?
The problem is when I use printers like Microsoft XPS or Cute PDF everything is OK, but when I try to print to local printer, print dialog opens every time...
regards
Sincerely,
Ekaterina
Developer Support Engineer
www.infragistics.com/support
Hello doomedmorale,
I have been looking into your question and as far as understand your requirements, you need to specify some settings and execute printing from the code behind. In the Reporting documentation there is an article that explains step by step, how to print reports programmatically:
http://help.infragistics.com/NetAdvantage/reporting/2011.2/CLR4.0?page=How_to_Print_a_Report_Programmatically_using_WPF.html
Please let me know if you need some further assistance regarding the discussed matter.
Infragistics, Inc.
