Is it possible to pass a parameter to the GetSpatialData() function, in order, for example to modify dinamically the sqlCommand ?
After selecting a country, I may need to select a region, then in that region a department, etc.
Max
Hello Max,
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thank you for your reply. I have been looking into the error that you are getting and I could not manage to reproduce it. Would you please, if possible, provide me with a sample application that demonstrates the issue, in order to be able to research what the reason for it might be?
I made a typing error. Please read "GetSpatialData() function" instead of "GetSpatialStata() function"
When, in the GetSpatialStata() function, I execute an sql stored procedure that returns up to 869 rows of geometry data, everyhting works fine. When I try with 870 records , I get the error message “Incorrect Endpoint Address Uri or WCF settings!”.
If I force Garbage Collection by adding a GC.Collect() instruction prior to the return statement , the number goes up to 1300 records.
Thank you for your patience during the investigation of the functionalty that you are looking for. I have contacted our development team and after a research, it turns out that this functionality cannot be achieve using the LightSwitch framework.
If you have any further questions please do not hesitate to ask.
