4110
UltraWebGrid-Row Edit controls not initializing
Please help. I have an UltraWebGrid (inside an update panel with a masterpage). Previously, I was able to determine the row ID that is assigned to textbox (hidden) in the RowEditTemplate and save the appropriate record. Now I've done something that isn't allowing the textbox to retain a value and I'm not sure what I have done. This is loaded dynamically once in the page_load event. Below is my code and html. Can someone please help. I just need to get the txtbox in the RowEditTemplate to initialize/retain the selected record id. I am using Infragistics 3.5 v10.3 controls. The controls in my RowEditTemplate are all asp controls, not regular input controls. Thanks.
 <asp:UpdatePanel ID="UpdatePanel1" runat="server" RenderMode="block" UpdateMode="Conditional">
 <ContentTemplate>
  <igtbl:UltraWebGrid ID="igMyGrid" runat="server" EnableAppStyling="True"
   StyleSetName="Office2007Blue" StyleSetPath="~/ig_res/" DisplayLayout-CellPaddingDefault="5">
   <Bands>
    <igtbl:UltraGridBand>
     <Columns>
      <igtbl:UltraGridColumn BaseColumnName="ID" Key="ID" Hidden="true">
      </igtbl:UltraGridColumn>
      <igtbl:UltraGridColumn BaseColumnName="NAME" Key="NAME">
       <Header Caption="Name">
        <RowLayoutColumnInfo OriginX="4" />
       </Header>
       <HeaderStyle HorizontalAlign="Left" />
       <CellStyle HorizontalAlign="Left" />
       <Footer>
       </Footer>
      <igtbl:UltraGridColumn BaseColumnName="VALUE" Key="VALUE">
       <Header Caption="Value">
        <RowLayoutColumnInfo OriginX="5" />
       </Header>
       <HeaderStyle HorizontalAlign="Center" />
       <CellStyle HorizontalAlign="Center" />
       <Footer>
       </Footer>
      <igtbl:UltraGridColumn BaseColumnName="OTHERTEXT" Key="OTHERTEXT">
       <Header Caption="Other Text">
        <RowLayoutColumnInfo OriginX="7" />
       </Header>
       <Footer>
       </Footer>
     </Columns>
     <RowEditTemplate>
      <div id="divMyGridControls_A" style="background-color: #E5ECFD; width: 550px;" visible="false">
       <p align="left" style="padding: 2px 2px 2px 2px; border-color: Lightgray; border-width: 1px;
        border-style: solid;">
        <asp:Table ID="tblMyGridControlsA" runat="server">
         <asp:TableRow Visible="false">
          <asp:TableCell>
           <asp:Label ID="lblMyGridIDA" runat="server" columnkey="ID"></asp:Label>
          </asp:TableCell>
          <asp:TableCell>
           <asp:TextBox ID="txtMyGridIDA" runat="server" Enabled="false" ToolTip="ID" columnkey="ID"
            BorderStyle="none" BackColor="#E5ECFD" ForeColor="#E5ECFD" Font-Size="0"></asp:TextBox>
          </asp:TableCell>
         </asp:TableRow>
         <asp:TableRow>
          <asp:TableCell VerticalAlign="Top">
           <asp:Label ID="lblName" runat="server" Text="Value" Width="75px"></asp:Label>
          </asp:TableCell>
          <asp:TableCell>
           <asp:RadioButtonList ID="rblValueA" runat="server" RepeatDirection="Horizontal" columnkey="VALUE">
            <asp:ListItem Text="Satisfied" Value="0"></asp:ListItem>
            <asp:ListItem Text="Unsatisfied" Value="1"></asp:ListItem>
            <asp:ListItem Text="Not Used" Value="2"></asp:ListItem>
            <asp:ListItem Text="Not Applicable" Value="3" Selected="True"></asp:ListItem>
           </asp:RadioButtonList>
          </asp:TableCell>
         </asp:TableRow>
         <asp:TableRow>
           <asp:Label ID="lblMyGridOtherText" runat="server"><br />Other</asp:Label>
          </asp:TableCell>
          <asp:TableCell>
           <button id="btnMyGridOtherText" runat="server" style="font-size: 8pt; width: 80px;
            cursor: pointer;" tabindex="3" type="button">
            Check Spelling</button><br />
           <asp:TextBox ID="txtMyGridOtherText" runat="server" columnkey="OTHERTEXT" Width="550px"
            TextMode="MultiLine" Rows="3"></asp:TextBox>
          </asp:TableCell>
         </asp:TableRow>
        </asp:Table>
       </p>
       <p align="center" style="background-color: #D5DDEA; vertical-align: middle; padding: 2px 2px 0px 2px;
        border-color: Gray; border-width: 1px; border-style: solid;">
        <asp:ImageButton ID="ibtnMyGridOK_A" runat="server" ImageUrl="~/Images/oknew.png"
         OnClick="ibtnMyGridOKA_Click" />
        <asp:ImageButton ID="ibtnMyGridCancel_A" runat="server" ImageUrl="~/Images/cancelnew.png" />
       </p>
      </div>
     </RowEditTemplate>
     <RowTemplateStyle Wrap="true">
     </RowTemplateStyle>
     <AddNewRow View="Bottom" Visible="Yes">
     </AddNewRow>
    </igtbl:UltraGridBand>
   </Bands>
   <DisplayLayout Name="igMyGrid" AllowDeleteDefault="No" AllowSortingDefault="No"
    AllowUpdateDefault="RowTemplateOnly" BorderCollapseDefault="Separate" CellPaddingDefault="5"
    AutoGenerateColumns="false" HeaderClickActionDefault="SortSingle" RowSelectorsDefault="Yes"
    RowHeightDefault="20px" NoDataMessage="No Data To Display"
    HeaderStyleDefault-Cursor="Hand" Version="4.00" CellClickActionDefault="Edit"
    SelectTypeRowDefault="Single" AllowAddNewDefault="No" AddNewRowDefault-Visible="No"
    ColHeadersVisibleDefault="Yes" HeaderStyleDefault-Height="10px" >
    <ClientSideEvents BeforeRowTemplateOpenHandler="igMyGrid_BeforeRowTemplateOpenHandler" />
    <FrameStyle>
    </FrameStyle>
    <ActivationObject BorderColor="" BorderWidth="">
    </ActivationObject>
   </DisplayLayout>
  </igtbl:UltraWebGrid>
  </ContentTemplate>
</asp:UpdatePanel>
#Region "igMyGrid Grid Methods"
    Protected Sub igMyGrid_InitializeLayout(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.LayoutEventArgs) Handles igMyGrid.InitializeLayout
        Try
            SetMyGridControls()
        Catch ex As Exception
        End Try
        With e.Layout.Bands(0).Columns.FromKey("ID")
            .Header.Caption = "ID"
            .Header.Style.HorizontalAlign = HorizontalAlign.Center
            .CellStyle.HorizontalAlign = HorizontalAlign.Center
            .Width = Unit.Pixel(25)
            .Hidden = True
        End With
        With e.Layout.Bands(0).Columns.FromKey("NAME")
            .Header.Caption = " "
            .Header.Style.HorizontalAlign = HorizontalAlign.Left
            .CellStyle.HorizontalAlign = HorizontalAlign.Left
            .Width = Unit.Pixel(255)
            .CellStyle.Wrap = True
            .CellStyle.BackColor = Drawing.ColorTranslator.FromHtml(Office2007Background2)
        End With
        With e.Layout.Bands(0).Columns.FromKey("VALUE")
            .Width = Unit.Pixel(425)
        End With
         With e.Layout.Bands(0).Columns.FromKey("OTHERTEXT")
            .Header.Caption = "Other"
            .Width = Unit.Pixel(325)
            .Hidden = True
        End With
    End Sub
    Protected Sub igMyGrid_InitializeRow(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.RowEventArgs) Handles igMyGrid.InitializeRow
        Dim Profile() As String = GetUserProfile(GetUser(Page.User.Identity.Name))
        Dim rblValueA As RadioButtonList = igMyGrid.Bands(0).RowEditItem.FindControl("rblValueA")
        Dim rblValueB As RadioButtonList = igMyGrid.Bands(0).RowEditItem.FindControl("rblValueB")
        Try
            If Not IsNothing(rblValueA) Then
                rblValueA.SelectedIndex = e.Row.Cells(4).Text
            End If
        End Try
        Try
            If Not IsNothing(rblValueB) Then
                rblValueB.SelectedIndex = e.Row.Cells(4).Text
            End If
        End Try
    End Sub
    Protected Sub ibtnMyGridOKA_Click()
        CheckItemsA()
    End Sub
    Private Sub CheckItemsA()
        Dim tSurveyIDA As TextBox = igMyGrid.Bands(0).RowEditItem.FindControl("txtMyGridIDA")
        Dim tOtherText As TextBox = igMyGrid.Bands(0).RowEditItem.FindControl("txtMyGridOther")
        Dim MyGridItems(4) As String
        Try
            If Not IsNothing(tSurveyIDA) Then
                MyGridItems(0) = tSurveyIDA.Text.Trim
            End If
                MyGridItems(1) = rblValueA.SelectedIndex
            End If
            MyGridItems(2) = "0"
            MyGridItems(3) = Today.ToShortDateString
            If Not IsNothing(tOtherText) Then
                MyGridItems(4) = tOtherText.Text.Trim
            End If
            UpdateMyGridData(MyGridItems, Profile)
            LoadData()
        End Try
    End Sub
#End Region
  • 4110
    Verified Answer
    This is okay now. I think what happened is that I needed to just close IE and restart the project. It seems I had some caching issues due to a number of changes I made on clientside.
