888
Cancelling an ajax deleteRow from the Code behind
I have an UltraWebGrid implemented with ajax updates and deletions working just fine.  The issue comes when the deletion/update occurs on the server, and due to constraints decides not to perform the deletion/update.  What I need to be able to do is cancel the client side deletion/update of the row and display a message to the user.  I am currently trying to hook into the XmlHTTPResponseHandler and AfterXmlHttpResponseProcessed events to try to cancel the deletion.
Is there a way to do this?  The gridResponse parameter on the XmlHTTPResponseHandler has a property Cancel - that is always False.  It I force this to True - the deletion does not happen - but I have no way to determine if the cancel needs to take place based on input from the server.  Any ideas?
Chad
  • 5
    Hi!
    Did you find a solution to this problem?  I was wondering about the same thing and your post came up when I searched the web.
    This is how I solved my problem.
    In code behind:
    Try
      'Delete operation...
    Catch ex As Exception
      gridClaim.ClientResponse.Tag = XmlHTTPRequestType.DeleteRow
      gridClaim.ClientResponse.ResponseStatus = XmlHTTPResponseStatus.Fail
    End Try
    In aspx file:
    function gridClaim_XmlHTTPResponseHandler(gridName, rowId, xmlResponceObject)
      if (xmlResponceObject.ReqType == igtbl_reqType.DeleteRow && xmlResponceObject.ResponseStatus != 0)
        xmlResponceObject.Cancel = true;
