730
Remove TileManager Header
Hi ,
I want to remove the Tile Manager Header : That is the whole background , text , border .
I want to use the tile manager to just show text and a Image  . I do not want to show the enclosure ( i mean the border ) .
  <ig:XamTileManager x:Name="TileMgrWidget"
                           Height="800"
                           MaximizedTileLimit="0"
                           FlowDirection="LeftToRight"
                           BorderBrush="Transparent"
                           Style="{StaticResource XamTileManagerStyle}"
                           ItemHeaderTemplate="{StaticResource UserHeaderTemplate}"
                           InterTileSpacingX="25"
                           InterTileSpacingY="25">
            <ig:XamTileManager.Resources>
                <Style x:Key="TileHeaderPresenter"
                       TargetType="igPrim:TileHeaderPresenter">
                    <Setter Property="HorizontalContentAlignment"
                            Value="Left" />
                    <Setter Property="Height"
                            Value="0" />
                    <Setter Property="VerticalContentAlignment"
                            Value="Center" />
                    <Setter Property="Foreground"
                            Value="Transparent" />
                    <Setter Property="Background"
                    <Setter Property="BorderBrush"
                    <Setter Property="Padding"
                            Value="0,0,0,0" />
                    <Setter Property="BorderThickness"
                            Value="0,0,0,0" />
                    <Setter Property="MinHeight"
                            Value="0" />
                    <Setter Property="MaxHeight"
                            Value="0" />
                    <Setter Property="HorizontalAlignment"
                            Value="Center" />
                    <Setter Property="Template">
                        <Setter.Value>
                            <ControlTemplate TargetType="igPrim:TileHeaderPresenter">
                                <Grid>
                                    <VisualStateManager.VisualStateGroups>
                                        <VisualStateGroup x:Name="CommonStates">
                                            <VisualState x:Name="Normal" />
                                            <VisualState x:Name="MouseOver">
                                                <Storyboard>
                                                    <DoubleAnimationUsingKeyFrames BeginTime="00:00:00"
        Storyboard.TargetName="ToggleMaximized"
        Storyboard.TargetProperty="(UIElement.Opacity)">
                                                        <SplineDoubleKeyFrame KeyTime="00:00:00.25"
        Value="1" />
                                                    </DoubleAnimationUsingKeyFrames>
                                                </Storyboard>
                                            </VisualState>
                                            <VisualState x:Name="Disabled" />
                                        </VisualStateGroup>
                                    </VisualStateManager.VisualStateGroups>
                                    <Border  CornerRadius="0,0,0,0"
                                             Background="Transparent" BorderBrush="Transparent" BorderThickness="0,0,0,0" >
                                        <Grid Background="Transparent">
                                            <Grid.ColumnDefinitions>
                                                <ColumnDefinition Width="Auto" />
                                                <ColumnDefinition Width="*" />
                                            </Grid.ColumnDefinitions>
                                            <Border Margin="0,0,0,0"
                                                    CornerRadius="6"
                                                    Grid.ColumnSpan="5" />
                                            <Path Grid.ColumnSpan="5"
                                                  Width="186"
                                                  Height="0" Fill="Transparent"
                                                  HorizontalAlignment="Right"
                                                  Margin="0,0,0,0"
                                                  VerticalAlignment="Bottom"
                                                  Data="M 0,15 C0,15 0,16 0,16 0,16 110.76,16 110.76,16 113.26,16 117.53,14.23 119.30,12.46 119.30,12.46 127.22,4.53 127.22,4.53 128.99,2.76 133.26,1 135.76,1 135.76,1 186,1 186,1 186,1 186,0 186,0 186,0 135.76,0 135.76,0 133.26,0 128.99,1.76 127.22,3.53 127.22,3.53 119.30,11.46 119.30,11.46 117.53,13.23 113.26,15 110.76,15 110.76,15 0,15 0,15 z"
                                                  Stretch="Fill">
                                            </Path>
                                        </Grid>
                                    </Border>
                                </Grid>
                            </ControlTemplate>
                        </Setter.Value>
                    </Setter>
                </Style>
            </ig:XamTileManager.Resources>
            <ig:XamTileManager.ItemTemplate>
                <DataTemplate>
                    <StackPanel x:Name="templateWidget"
                                Orientation="Vertical"
                                ScrollViewer.VerticalScrollBarVisibility="Disabled"
                                Background="Transparent" Margin="0,0,0,0" >
                        <Image Source="{Binding MenuImagePath}"
                               VerticalAlignment="Center"
                               HorizontalAlignment="Center"
                               Height="100"
                               Width="100" />
                        <TextBlock x:Name="txtBlkMenuName"
                                   FontFamily="Verdana"
                                   Text="{Binding MenuName}"
                                   FontSize="11"></TextBlock>
                    </StackPanel>
                </DataTemplate>
            </ig:XamTileManager.ItemTemplate>
            <ig:XamTileManager.NormalModeSettings>
                <ig:NormalModeSettings TileLayoutOrder="Horizontal"
                                       MaxColumns="4"
                                       AllowTileSizing="No"
                                       AllowTileDragging="No"
                                       ExplicitLayoutTileSizeBehavior="SynchronizeTileWidthsAndHeights"
                                       MaxRows="10" />
            </ig:XamTileManager.NormalModeSettings>
        </ig:XamTileManager>
My Resource dictionary is:
<ResourceDictionary xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"                     xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"                     xmlns:ig="http://schemas.infragistics.com/xaml"                     xmlns:igPrim="http://schemas.infragistics.com/xaml/primitives">     <SolidColorBrush x:Key="TilesControlBorderBrushFillKey"                      Color="Transparent" />          <DataTemplate x:Key="UserHeaderTemplate">         <TextBlock Text="" Margin="0,0,0,0" Padding="0,0,0,0"  Height="0"  MaxHeight="0"/>     </DataTemplate>                   <Style x:Key="XamTileManagerStyle"            TargetType="ig:XamTileManager">         <Setter Property="Background"                 Value="Transparent" />         <Setter Property="BorderBrush"                 Value="White" />         <Setter Property="BorderThickness"                 Value="0,0,0,0" />         <Setter Property="Padding"                 Value="0,0,0,0" />         <Setter Property="ScrollViewer.HorizontalScrollBarVisibility"                 Value="Auto" />         <Setter Property="ScrollViewer.VerticalScrollBarVisibility"                 Value="Auto" />         <Setter Property="igPrim:XamlHelper.CanContentScroll"                 Value="true" />         <Setter Property="VerticalContentAlignment"                 Value="Center" />         <Setter Property="TileAreaPadding" Value="0,0,0,0"></Setter>                <!--<Setter Property="ig:XamTileManager.ItemHeaderTemplate">             <Setter.Value>                 <ControlTemplate TargetType="ig:XamTileManager">                     <Border x:Name="Bd"                             BorderBrush="{TemplateBinding BorderBrush}"                             BorderThickness="{TemplateBinding BorderThickness}"                             Background="{TemplateBinding Background}"                             Padding="{TemplateBinding Padding}"                             CornerRadius="6"                             Margin="0,0,0,0"></Border>                 </ControlTemplate>             </Setter.Value>         </Setter>-->                    <Setter Property="Template">             <Setter.Value>                                 <ControlTemplate TargetType="ig:XamTileManager">                     <Border x:Name="Bd"                             BorderBrush="{TemplateBinding BorderBrush}"                              BorderThickness="{TemplateBinding BorderThickness}"                             Background="{TemplateBinding Background}"                              Padding="{TemplateBinding Padding}"  CornerRadius="6" Margin="0,0,0,0"                              igPrim:XamlHelper.SnapsToDevicePixels="true">                         <ScrollViewer BorderThickness="0"                                       igPrim:XamlHelper.Focusable="false"                                       HorizontalScrollBarVisibility="Auto"                                       Margin="0"                                       Padding="0"                                       VerticalScrollBarVisibility="Auto">                                                              <igPrim:TileAreaPanel x:Name="TilePanel" Margin="0,0,0,0"  UseLayoutRounding="True"                                                   igPrim:XamlHelper.SnapsToDevicePixels="{TemplateBinding igPrim:XamlHelper.SnapsToDevicePixels}" />                         </ScrollViewer>                     </Border>                 </ControlTemplate>             </Setter.Value>         </Setter>     </Style>    </ResourceDictionary>
My code is:
