20
How do I manually show the SelectedGroupPopup?
I am using the XamOutlookBar for silverlight.
I would like to set up events so that when the the xamoutlookbar is minimized and the user clicks on a group header icon, that the popup for that group is displayed.
This is similar to the behavior that already exists when the user clicks on the navigation bar.
Any ideas?
  • 1670
    Sorry for the late response, but if you still have not find a solution for implementing that, here I am suggestiong you the following solution. You should use command for when selecting a group. So the code as it follows:
    Let assume that is my XamOutlookBar
    <ig:XamOutlookBar x:Name="xamOutlookBar" Height="400" Width="400" SelectedGroupChanging="EventHandler_Selection">
                <ig:XamOutlookBar.Groups>
                    <ig:OutlookBarGroup Header="A" Content="AAAAAAAAA"></ig:OutlookBarGroup>
                    <ig:OutlookBarGroup Header="B" Content="BBBBBBBBB"></ig:OutlookBarGroup>
                    <ig:OutlookBarGroup Header="C" Content="CCCCCCCCC"></ig:OutlookBarGroup>
                    <ig:OutlookBarGroup Header="D" Content="DDDDDDDDD"></ig:OutlookBarGroup>
                    <ig:OutlookBarGroup Header="E" Content="EEEEEEEEE"></ig:OutlookBarGroup>
                    <ig:OutlookBarGroup Header="F" Content="FFFFFFFFF"></ig:OutlookBarGroup>
                </ig:XamOutlookBar.Groups>
            </ig:XamOutlookBar>
    and the handler for SelectionGroupChanging is as follows
    private void EventHandler_Selection(object sender, SelectedGroupChangingEventArgs e)
                if (this.xamOutlookBar.IsMinimized)
                    Commanding.SetCommand(e.NewSelectedOutlookBarGroup, new XamOutlookBarCommandSource()
                        EventName = "MouseLeftButtonUp",
                        CommandType = XamOutlookBarCommand.ShowPopup,
                        Target = this.xamOutlookBar,
    Note that the Popup will open on double click! Please respond if you have any other questions. Thank you!
    Nikola.
