35
How to change Tile source
Hi, I'm really interested with this product (Map) and currently is using the trial version. My question is how to change the Tile source (in Layers tab), because when I tried to change it to CloudMade or Bing, it goes back to OpenStreetMaps. Is this option (change Tile source) only available for licenced user? Thanks.
  • 255
    You can also follow the help procedure here: http://help.infragistics.com/Help/NetAdvantage/SharePoint/2011.2/CLR4.0/html/Use%20Different%20Tile%20Source%20Providers.html
  • 138253
    Thank you for your post. I have been looking into it and I can say that if you want to use CloudMade or Bing you need to have a Key from the vendor. Here you can see a sample where there is filed for entering a Key and if you enter a valid one you will be able to use the map:
    http://sharepoint.infragistics.com/Map/default.aspx
    Hope this helps you.
