I have some webcombo controls with lists of data in them.
The issue is that when the user scrolls to the end of the list, the scrolling jumps to the page instead of staying inside the combo control. Is there a way to prevent this?
Hi
I have also same issue...
Hi Daryl007,
I have created a private case for you to further address this issue. I will send updates to the private support case.
Here is the problem.. I am not sure if this is by design or not.
Take your example, now add a webgrid and make the hieght 2000px. force it to make the screen scroll.
Now scroll your list , when you get to the end of the webcombo box it jumps out and scrolls the page.
Please let me know if you need any additional assistance regarding this matter.
I modified my test sample to source an xmlDataSource referencing a list of states, and re-tested using the mouse wheel to move-up-and-down my list. I was unable to reproduce the issue you are reporting.
I have attached my test sample for you reference. When you have a moment, give it a look. If you can modify my sample such that it produces the issue, let me know and send back the modified sample. I will then give a further look.
Also, let me know which browsers you are using where experiencing this problem
Let me know if I can be of any further assistance regarding this matter.
