I'm trying to change the content of the list in xamComboEditor based on the value entered in another column. When I do that and click off the record being edited I get the following exception.Message: Unhandled Error in Silverlight Application Operation is not valid due to the current state of the object. at System.Windows.Data.BindingExpression.UpdateSource() at Infragistics.Controls.Grids.CellControl.EvaluateEditingBindings() at Infragistics.Controls.Grids.XamGrid.ExitCellFromEditModeInternalRow(Boolean cancel) at Infragistics.Controls.Grids.XamGrid.ExitEditModeInternal(Boolean cancel) at Infragistics.Controls.Grids.XamGrid.SetActiveCell(CellBase cell, CellAlignment alignment, InvokeAction action, Boolean allowSelection, Boolean setFocus, Boolean scrollIntoView) at Infragistics.Controls.Grids.XamGrid.SetActiveCell(CellBase cell, CellAlignment alignment, InvokeAction action, Boolean allowSelection, Boolean scrollIntoView) at Infragistics.Controls.Grids.XamGrid.SetActiveCell(CellBase cell, CellAlignment alignment, InvokeAction action, Boolean allowSelection) at Infragistics.Controls.Grids.Cell.OnCellMouseDown(MouseEventArgs e) at Infragistics.Controls.Grids.XamGrid.XamWebGrid_MouseLeftButtonDown(Object sender, MouseButtonEventArgs e) at MS.Internal.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args) at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName)
Thank you,
Eugene
HI Eugene,
Can you please attach a small isolated sample with steps to reproduce.
Sincerely, Matt Developer Support Engineer
