590
Difference between report designer and preview
I have the following markup in Report Designer:
But the Report Preview does not show exactly what we expected to see.
Is there any way to remove free space between images (distance between images depends on rows number of the table)?
  • 138253
    Hello Andrey,
    It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I can suggest you put the two Images in a Table with one column and three rows. You can use the middle Row’s Height to determine the distance between the two images. Also you can set the Table’s GridLinesColor to whit, so the table won’t be visible at all. It will be used as Grid.
