Just purchased the LS controls. Numerous issues, but here are the major ones:
1 - LS' built-in Address Viewer control causes error on the screen and does not load the column: "A column has been added with an empty key. All columns must have a unique key." I use the address viewer control all over my app as i'm sure many people do since it is a built-in control. Please fix this issue. This should be fundamental to a grid replacement for LS' grid. Also, once you hit OK to proceed, if you leave and return to the screen, the LS app crashes with "Object Reference Not Set To An Object".
2 - Display Names are being ignored in favor of the field names at column headers and groupings. This is also a fundamental feature of LS and can't be ignored. Please fix.
3 - The main reason I purchased the grid was for the column-level filtering that is shown on your website screenshots. But I can't find how to make the filter row appear. How do you make the filter row appear?
Rob
To all interested,
A new service release is available which resolves the issue of the display name not being used correctly. The unique key issue with regards the Address Viewer has also been resolved in this service release.
You can download the latest service release by going to the Infragistics website and hovering over the "Account" tab then selecting "My Keys & Downloads" from the dropdown. On the "My Keys & Downloads" page you will see a list of product keys. Select the product key assigned to the product you wish to update and then scroll down the download list until you reach the Service Releases section.
I have created private cases for both canderson70 and titaniumsoftware and linked them to the development issues described above. This will automatically send you an update once the fix has been released.
You can view the cases on the Infragistics website by hovering over the "My IG" tab and selecting "My Support Activity" from the dropdown list. The case will appear in your Active tab. You can view the status of the development issue connected to this case by selecting the "Development Issues" tab when viewing this case on the web site.
I will also post here when the fix is released.
The display name issue is very important to us. Please notify me when it is fixed.
The Address Viewer issue (Dev ID 98620) and display name issue (Dev ID 96703) have been fixed internally and are currently awaiting testing by our QE staff. I will update this thread when they complete the testing phase and have a definite release date.
Have the above issues been resolved?
